Got my Gamefisher fully IDed. It is a 1979 with a Tecumseh motor and was made by Eska. The pull start won't engage the gears on the flywheel. It worked for awhile. Now there is a small spring loose and I can't figure out how it goes. Anyone got a pic of that? Also, the lower unit has a broken tooth on the gear that comes out with the prop and there were a bunch of needle bearings loose in the gear lube. Suppose I need a whole lower unit. Anyone got one they'd part with or maybe just an exploded view so I can get it apart and fixed.
