I'm replacing the wood backing on a couple of fiberglass hatch covers. I have removed the rotten wood, ground down all the rough edges and am ready to glass in the new 3/4" ply backing. I will be using poly resin and have both fiberglass cloth and matt.<br /><br />1. I need advice on how to put the glass on the wood so that I don't get a lot of air pockets at the edges of the wood. Would it be best to use matt or cloth? <br /><br />2. Is there a way to lengthen the pot life of the mixed resin? I have used resin before and have often found the pot life to short or had difficulty in getting it to cure.<br /><br />3. Would 5200 be the best way to seal some bolt holes that I have to drill through the finished covers so that I don't have to do this again?<br /><br />Howard<br />Miami Fl
