need for speed
redranger
I'm running a 95 ranger r70 with a 90 horse johnson and would like to know the best way to gain more speed other than upping the horses.How much difference would a jack plate or stainless prop make? If anyone is running this same set-up <br /> with a 130 horse i would like to know top speed.<br /> Mine is only running around 41-42
Dhadley
Re: need for speed
Let us know what top RPM you can get with an average load and what prop size and style and we can calculate theoretical speed and slip. Lets establish a baseline and go from there.<br /><br />Good luck!
Dhadley
Re: need for speed
redranger
Re: need for speed
I'm running around 5400-5500 according to my tach,but it doesn't work properly.I am running an aluminum 17 pitch prop. <br /><br /> thanks for your help
roy w. shakun
Re: need for speed
likely, you can get a couple more mph with a stainless prop of good quality. sounds like your right in your operating range. how fast is enough?
Dhadley
Re: need for speed
At 41 MPH you are at 10% slip which is great. You need to get the RPM up to gain speed, lift, reduced drag, holeshot and engine life. A quality stainless prop (like Stiletto or Turbo) will allow you to do that.<br /><br />Good luck!
