Need fuel lines checked
lockerbie55
I have 2 fuel lines coming from the manual choke on a 1982 jonson 115 I need to know where they cmgo to the carburetor the size of the fuel lines to replace and a diagram of the lines going n coming from each piston to the carburetor need to run
It is not a manual choke.----It is a primer valve.----Opens when you push the key in WHILE cranking the motor over for cold start.
lockerbie55
Yea it has electric or manual if u turn the red valve to manually choke it but the issue I have is the 2 limes on bottom of them was disconnected n dry rotted so I removed them but I need size of the fuel lines and 2 of the lines going to pistons and I need the brass connector for the line going to piston is it able to be replaced without the entire house like is it a press in or screw In
tphoyt
I want to say 7/64 ID for the primer lines.
If you broke the brass nipple you will likely need to remove the intake and punch it out from the backside.
lockerbie55
Ok wasn't sure if it works just pull out with a pair of pliers and ephod u have a diagram of which line goes to which each piston I need 2 lines and where the lines go from the primer valve
