Need Fuse panel diagram 92 3.0 alpha 1
Sevenscrew
I need a fuse panel diagram for my 17' glastron 3.0 alpha one inboard outboard. I see a few spots where fuses are missing . Also I took one by one out to check and I'm not 100% sure I put them back in correct spot because there's 1 missing in between some of them
Bt Doctur
Re: Need Fuse panel diagram 92 3.0 alpha 1
is there a wire connected to the missing fuse screw? install fuses in all of them or see whats not currently working.
Silvertip
If you are talking about a fuse panel located at the helm, that is "Boat" electrical system diagram you are looking for, not an "Engine" diagram. +12 volts goes into one end of all fuses. Current then passes through each individual fuse to whatever circuit that fuse protects. So if there is no wire on connected to an empty fuse slot, no fuse is needed. If there is, then determine what that circuit is for and fuse it accordingly. Most circuits on a boat like yours can live nicely with a 7.5 or 10 amp fuse. Use the search feature for typical boat wiring diagrams. This wiring is very generic. The feed from the battery to the fuse panel at the helm should be #10 or #8 gauge. 10 gauge would likely be more than adequate for existing loads.
