need gas assist or something for 25hp yamaha
Sean757
I have a remote '03 25hp 4-stroke yamaha with a 15" shaft that sits under a low polling platform and is near impossible to reach around and lift it up. the problem is the 15 inch shortshaft cant come with factory trim and\or tilt. i found out that the other small/mid range motors have some sort of gas assist to aid in lifting the engine up. if there is any advise on where to find such a thing, let me know. <br /> thanks
bubbakat
Re: need gas assist or something for 25hp yamaha
Yes it will cost but it is worth every penny of it. Just got thru installing a pt135 on mine and it is easy to do and works like a charm.
Forktail
Ensign
Why can't you get, or add, factory TT on the 15" shaft, or adapt the TT from the 20" shaft? :confused: <br /><br />Factory TT should be available for that 15".
jtexas
How about a pulley on the underside of the polling platform with a rope attached to the L/U and on the other end a weight just less than the force required to lift the motor? :D :D <br /><br />Better yet,attach the free end of the rope to a bucket and let it drag behind the boat - the motor will lift itself. No, wait, that won't work...
Sean757
thanks for the replies. Ill check on the factory trim\tilt but when ordering the motor i was not able to get one with TT. i will call Jacks Interbay Marine on the west coast of florida for more news.
