ntoracn@yahoo.com
- Joined
- Jun 29, 2004
- 86
I bought this 12' Sears boat with a 1976 9.9 outboard. My first trip out on the lake resulted in the bottom spark plug fouling after 10 min. of running time. I thought I had a driver coil issue, so I replaced it , new coils,gapped the points at .020", replaced the condensors and replaced the L77JC4 spark plugs with fresh ones.<br /><br />Today I take it out on the lake and have the same problem but now it will run for 15 min. befor it fouls the bottom plug. I replace the plug and I'm up again for 15 more min. ARGH!!!
<br /><br />Then I found that if I turned the idle mixture screw all the way in (lean) at wide open throttle, I can run for 20-30 min and not foul the plug. So I pull the carb thinking I have a bad float (no, but it's cork) or the previous owner installed a larger jet (no, it's the stock .051").The float looked fine also<br /><br />What is going on with this motor!!! Why is the lower spark plug the only one that is fouling?<br />I did a compression test and had 80 psi on both cyls. <br /><br />Could I have a bad reed? I don't think so as I have no fuel blowing back out of the carb.<br /><br /> As a automotive tech, this is really getting me mad. I'm about to make a boat anchor with this thing. I will take ANY advice, PLEASE!<br /><br />Thank You.
