need help 1964 evinrude controls
sumizzel
i have a 1964 evinrude controls .in side the controls there are 3 wires for the eltroncs shift there are 2 on one side and 1 on the other side i do not know which order they go in. and i tryed to start the motor and nothing happen so we jump the silnod and it will start need help
Joe Reeves
Re: need help 1964 evinrude controls
Look closely at the terminals on that shift switch. One is marked "F" for forward, the other is marked "R" for reverse.
Green wire from the wiring harness connects to the "F" terminal.
Blue wire from the wiring harness connects to the "R" terminal.
Voltage wire connects from the "A" terminal of the ignition switch to the remaining terminal of that shift switch.
sumizzel
i got another ? for you i need help with starting my boat motor . i have a box with all the wires going to it and it have the cylinoid in it. i turn the key and nothing happen there are 3 wires a heavy green and a heavy brown one and a small brown one with a fuse do not know where they go. on the cylinoid there are 4 nut on it 1 left 2 in the center and 1 on the right. when i take a wirer and tuch the right one and the center one on the left side and tune the key the starter will move slow and the cylinoid will pop like crazy.but when i take the wirer and jump the cylinoid to the right side and the center one next to it the starter will move like it spost to and the motor will start up. so what do i need to do to start the motor by the key.
Joe Reeves
Received PM and answered it pertaining to the above question.
sumizzel
i got a nother ? for you i put the boat in the water an when i go forword it will pick up speed slowly and it not very fast i have a 90hp and when the throlled is all the way down the motor boges down do u know what it wrong if you do how to fix it
Joe Reeves
If you have compression and spark on all four cylinders, suspect a fouled carburetor.
