Need help 1988 50hp Evinrude.
Robs88
Hey guys i have a 1988 evinrude 50hp, engine has good spark, compression and fuel, and wont start! or even attempt to start, just turns over. Can anyone give me suggestions on what else can this be, or where to look thanks.:)
Joe Reeves
Re: Need help 1988 50hp Evinrude.
Compression should be 100+ psi and even on both cylinders. Is it?
With the spark plugs removed, the spark should jump a 7/16" gap with a strong blue lightning like flame.... a real SNAP! Does it?
If the two above areas are as they should be, I'd suspect fouled carburetors.
Did you just purchase this engine, or have you owned it for some time? If for some time, when was the last time it ran as it should? Spark plugs should be Champion QL77JC4 plugs gapped at .040 or .030 (your choice).
Does the engine attempt to fire/run if you spray some pre-mixed fuel into the carburetor throats? If it does, that brings us back to fouled carburetors.
Let us know what you find.
Robs88
Found the problem it was the electric choke not injecting fuel for start up . thanks for the reply.
