creative993
- Joined
- Jul 5, 2009
- 5
I need help with the above subject. I am a nebiee to this site so any help you could provide will be appreciated. First i had long steady beeeeep, after reading I have replaced water pump, impeller, thermostats, temperature switch, fuel line, fuel filter, etc. After the replacement of the above parts I get a beep beep every 5 seconds or so. IThe beep noice starts once I apply full throtle, once I reduce the throtle it stops. Any help or suggestions??
I am running currently on a portable 6 gallon fuel tank until I can resolve problem. I beleived I need to replace the fuel tank which is locate in the center console. This will be a fall or winter project. I have new wiring from the gauges, new speedometer, the tach does not work. I don't thik this will cause the problem but I am giving you as much info as possible. Again, any help you could provide me will be greatly appreciated.
Thanks again,
JD:
Thanks again,
JD:
