Hey All,<br /><br />84 Renken boat, Aqa125 4cyl volva motor. The timing belt tensioner went bad. Have all the parts and trying to put the new timing belt on the boat however its to tight??? The tensioner has a spring that puts tension on the bearing. They say to put a pin in the spring to keep it from putting to much tension on the belt and when its installed, remove the pin and it will self adjust. <br /><br />Well I am doing this but the belt still won't go on. Any ideas? PLEASE HELP!!!
