boatingfromthepoorhouse
- Joined
- Mar 17, 2007
- 29
my earlier post must not have been written well enough. I have no spark or fire from my #1 plug. I swapped the wires, no change. I pulled the coil pack, ohms out equal on both sides. checked orange wires from POWER PACK? ohmed to ground wire that is mounted under the coil pack. top wire reading is different than bottom, but not by much.
top = 155ohms
bottom = 140 ohms
does this indicate the power pack is ok and I should check the stoator? I just want to avoid spending money on unnecessary parts that cannot be returned! thanks for the help.
(1997 50 hp evinrude 2cyl 2 stroke remote)
top = 155ohms
bottom = 140 ohms
