Re: Need help choosing a prop
From my lessons learned, the higher pitch prop - the lower rpms, i.e. for every inch of pitch is 150 to 200 rpm difference. The lower the pitch, the less top speed. Right here under IBoats.com prop section on the bottom explains a bit about pitch and rpm's, etc. Theoratically - 17p prop will move 17" thru the water - 21p prop will move 21" thru the water per one revolution of prop, hence the gain of top end speed with the 21p over the 17p. But talking props, there are numerous factors in choosing a prop, and the afore mentioned is just touching the surface.
There are alot of very knowledgable persons on this forum that know their sh*t about props and have guided me in the right direction and/or given me more insight than one would have imagined about props. Check out the adult section of the stickies under props to provide detailed info and I'm sure the experts will be by shortly.....
