The Wright Stuff
- Joined
- Apr 11, 2005
- 34
I posted my problem before that I had water leaking out out the top spark plug hole. Well I was told it was a water jacket problem and not a big deal to change the gasket. I had taken it to a local marine mechanic and just talked to them today.<br /><br />They said that it was a water jacket leak. BUT, they said they couldnt get all the bolts out to fix it as two appear that they will break if they try to remove them. They said if that happens it would be expensive to fix it, so they tried just using silicone to seal the leak but it didnt help. <br /><br />He said that it can stay leaking and it will not hurt a thing besides leaving it a little wet under there. Does this sound right? That a leaking water jacket that leaks water out of the spark plug hole can be left leaking and not cause any problems? The guy I bought it from(no, he's not a mechanic) said that I should have it fixed before running it under load or it could damage the engine. Any help is appreciated.<br /><br />Oh, I dont think the mechanic is trying to scam me as I told him to change the water pump as well but he said he checked it and it was fine so he left it alone to save me the money.
