Re: Need help determing model
I'm sorry, what I meant is exactly 15'. My 1963 15' Jet is
really 14' 9" :facepalm: And other years & models varied +/- from 15'. The spec sheet, from FG I posted, for 1967 lists the Jetstar as
15' so it's probably 15'.
My Jet was previously registered as a 1974, but it's clearly not. And that's fairly common to have it titled or registered incorrectly. It's now titled as a 1963, but WV doesn't recognize anything but the foot measurements for titles & registrations, so when I listed it as 14' 9", the DMV dropped the 9" & it's listed on the reg & title as a 14'.... 1 step forward, 1 step back... Not worth the trouble to me to change it, so I'll leave it. Besides, my boss & I already have an agreement for him to buy it. So when he transfers the title he may change it, but probably not.
BTW: The OB looks it might be an electric shift model. If you can't see & hear the motor running & the prop spinning in both forward & reverse, consider the motor as NON-EXISTENT for the purposes of the buying the boat. In fact, a wet test drive would be better. When they work, they work fine. But it can be tough to find the parts (electric shifting solenoids) in the gear case of the lower unit, when they start to fail.
If the OB has a shift lever on the starboard side of the motor, it's not electric shift.
google
electric shift johnson & you can read thru some info about the motor, if it's electric shift.
The 1967 Jet could also take at least a 50hp motor, as listed on that spec sheet. So you may be looking to re-power it soon anyway.
As always, try to get the best deal you can, be prepared for someone else to pay full asking, and to have to walk away if the seller won't deal on price (esp if electric shift or you don't see it running).
In this last pix, it looks like there's a gear shift cable loose & just hanging there on the left side of the pix. That should indicate that I am incorrect & it's a mechanical shift, not an electric shift. But see if the seller will give you the model #. Then you can confirm it's a 1967 +/- OB & electric/manual shift.
You can go thru the 1967 Johnson's parts lists
here. If the model isn't listed, go back up thru the years before & after 1967, or try just listing the model#, that website may find it's year & etc for you from that #...
When are you going to be able to get your hands on her & decide yes or no about the purchase?
