niterod2183
- Joined
- Jun 26, 2008
- 4
All I get is a click from the slave solenoid. Just replaced the slave solenoid and starter solenoid and get the same exact click. I am reluctant to pull the starter until I am 100% sure that is what it is. I followed instructions on testing the slave solenoid and when I hook my test light to terminal A and touch terminal D(ground terminal) it does not light up as it should.
My Questions are:
1)How do I fix a bad ground?
2)How do I test the starter if it will engage the engine before removing the starter?
3) I have a skinny wire coming up from underneath the engine taht has a fuse connected to the wire. It comes off of what looks like a pedal uderneath the engine. Anybody have any clue what this does and wherre it should be connected as it is disconnected right now?
1989 Mercruiser 3.0 inboard
Any help is much appreciated as I have reached a dead end to what the problem is.
My Questions are:
