danielsmith
- Joined
- Jul 9, 2013
- 1
ok so i go this boat motor the other day for free. i solved the no spark issue then i took the carb apart to clean it and the rubber tipped needle that attaches to the float is missing and in its splace was a twisty tie that someone tried to rig up i quess. (no wonder i found this motor out by the street in the trash.) anyway after searching the net and ebay i found out that supposedly this needle is nla and obsolete. so i need to know how to track down a proper alternative. here is all the details and numbers i can find on my motor and carb.
sears 217-58991 which i found is a 1971 sears gamefisher ted williams etc.
it is a tecumseh with the number 610751 on the flywheel
the motor tag bolted on the side of the motor which i believe is a tecumseh number is t-643-15-a and also 6443469 all on the same tin tag.
on the carb it says 395 OE8
so where can i find a needle that will work, when i ebay searched tecumseh carb rebuild kits there are a bunch but how do i know if the needle in this kit will fit be the right length and width etc. thanks for any help in tracking down what and where i can get a missing needle.
