Need Help Finding Oil/Temp Sensors
Five O'Clock
Does anybody have pics or can help with location of the 4 sensors that would activate the alarm in a Volvo 5.7GXi-E?
I'd be looking for the Oil Pressure Sensor, the high temp sensor, and the sensor on each manifold?
frankofmontreal
Re: Need Help Finding Oil/Temp Sensors
I will go to my boat and take pictures for you !!!
Oil sender for the guage it is located under spark plug wire number 7 and is looking like a small bell !!!
The oil pressure switch is on the right side of the engine facing rear of boat look slighly higher on top of the location of the oil filter and if you have a oil filter remote system like i have that sender is easy to find look for a lonely wire that plugs into a wire socket
Link for the bell like sender
http://www.shopping.com/Sierra-Oil-...arine-Power-0940102-Crusader-700403/info?sb=1
Link for the pressure switch.
http://www.iboats.com/Oil-Pressure-Switch-for-OMC-Volvo-Mallory/dm/view_id.794835
Frank
Don S
All switches have a tan/black striped wire going to them. The coolant temp switch should be near or on the thermostat housing.
The exhaust switches are found on the top aft of the exhaust elbows.
The oil pressure is either just above the oil filter housing on the block (port side, just above the oil pan) or next to the distributor.
cobalt1999
Hey Mr. Moderator, You are responding to a thread that is a day short of one year old.
Don S
Wouldn't have if a newbie hadn't dug up an old thread to reply to. :facepalm:
