boat_chick
- Joined
- May 3, 2010
- 7
The hardware that holds the windshield on my '75 Bayliner Mutiny is rusted off on the starboard side and the whole section is loose. The only thing holding the main section on is the support bar and the side section. It looks like they have some sort bolt with a thin wide head that slides in under the windshield frame, then bolts through the deck with a washer and nut on the underside. It's hard
to tell because they didn't use stainless so they are really rusted up. Does anyone know where I could find new ones? Thanks a bunch. Also, does anyone have a used 12' steering cable for a rack system on an Alpha One? someone decided that since the boat is 16', the cable should be, too!
Thanks for the help!
