Hi, i have a spectrum 1700 with 1989 force 85hp ob. it is sluminum hull.
When i go WOT, the rpm read 4500. and the speed is 31 mph according to the GPS. I read on the forums people with the same settting can get the the boat up to 40mph. I am going to do a compresstion test and are confuse with some of the steps.
1) the manual said that I have have to do the test when the engine is warm. is that right?
2) I am going to use a battery to run the starter instaed of using the key. so that I can by pass grounding the spackplug. is that ok?
