ericlcarter1
- Joined
- Jun 2, 2008
- 9
I got a freebie. 2002(?) Mercury 150 Saltwater. It was free but I have no history on this motor. I went and looked at it last weekend and went back and got it yesterday. The boat it was on was trash, but when I lifted the cowling everything underneath looked great....no signs of corrosion at all. The engine was covered with the cowling on.
The only things besides the motor that made the trip back were the throttle and shifter cables. I left the wiring harness behind thinking it would need a new one anyway.
Once I get a harness what procedures should I go through to see if this motor will crank or even turn? Starting fluid? Take the plugs out and put in some oil? I will need to get a new ignition, so once the harness is on and the ignition is connected and the cables to the binnacle, should I just be able to hook a battery up, put some water through it and see if it cranks? What order would you guys that have done this for a while follow? I know it's been a couple of years since it was cranked. Would you just take it to a shop and let them see?
Any suggestions will help....Thanks, Eric
