Need help identifing wires or wiring Diagram
crb478
I have a 1986 yamaha 115 2 stroke with some wires that I am trying to identify. The prior owner put this motor on a pontoon boat and tried to match up two different wiring harnesses. Right now it is really cobbed together and full of crimp on butt connectors and wire splines with several wires just cut off.
Comming out of the control box there are two wire looms that I can not identify. The first has four wires in it, a black (seems to be a ground) , 2 yellows ( one which is an ignition switched hot) and a pink. The second loom has a Green, a Black , and a yellow. I have a service manual for a 1984 yamaha, but the color combinations do not match up. Can any one either provide me with a wiring diagram or identify where these wires are supposed to go.
Also I have 4 check lights on my speedometer that will light up an go out. I can only hope that they are wired up correctly, but I noticed that there is a buzzer in the remote control. That buzzer never goes off. Is it supposed to beep whenever you start the boat or just when there is a problem. Right now I am not sure it works at all. Thanks for any help.
