need help identifying a part on 1982 Evinrude90
Thrilliot
i can't seem to find this bracket/part in any diagram or manual i have read. it is the pivot arm that the entire motor turns on. its quite corroded and the bearing sounds like it needs to be changed out. if anyone can help it would be greatly appreciated. i will try to get a picture asap, but the lights in my garage currently aren't working :facepalm:
James R
Re: need help identifying a part on 1982 Evinrude90
Go to boats.net and plug in your motor. Go to exhaust housing and there it is.
Joe Reeves
#43 = Steering Arm......... #1 = Swivel Bracket
Thrilliot
thanks for the help! only problem now is that the part is unavailable on the site -_- hopefully once its warmer out and i get the motor apart it will just be superficial damage and nothing to the structure. Thanks again!
tx1961whaler
If it is a 25 inch leg, then the swivel bracket is still available. Part #0389336. If it's a 20 inch model, then it looks like you're out of luck for a new part.
Thrilliot
i believe its a 20", but i'll have to double check. does anyone know if the bracket is the same for other years? otherwise looks like i'll be doing some fabrication
Thrilliot
I've come across some information that says as long as it is a 20" shaft, all upper steering arms for V4's, V6's and V8's are the same from 1982-1997. Can anyone else confirm this?
Silvertip
And this place will likely have a used one. Twincityoutboard.com
