Need help identifying Evinrude Outboard with Power Tilt and Trim
fire7882
When I bought this outboard, the previous owner told me it was an 88 model but I can't find any numbers on it. I think the power tilt and trim arn't origional but can't be sure.
The electric motor on the tilt and trim unit needs new brushes and I need to order parts for the engine soon. Any help with identifying the engine and tilt/trim would be greatly apreciated.
HighTrim
Re: Need help identifying Evinrude Outboard with Power Tilt and Trim
Ill assume that the id tag on the port stern bracket is removed, but how about the welch plug? It is about the size of a quarter, and will be located on the top, rear of the head. It should contain the model number.
tashasdaddy
it appears to be an 4 cylinder V4 88 or premix 90 hp. you model and serial # are on the silver plug. post #'s we can tell you.
fire7882
Edit: My post was answered before I posted this reply
I don't have the motor with me and I won't be able to look at it until thursday but does the picture below have the plug you are talking about?
BTW, it dosn't look like there was ever an id tag on the port stern bracket. There are no holes or signs of one being there.
fire7882
OK I see. I will get the numbers as soon as i can. Thanks tashasdaddy and HighTrim
fire7882
I got someone that is going to look at the motor for me and call me with the numbers. I should have them tonight. Thanks again for the help.
fire7882
The numbers are:
E90TLCCA
R1810817
fire7882
Thanks for the help everyone. This site is awsome.
Does that tilt and trim unit look original? How are these numbers originaly attached the to transom mount?
