Need help identifying ignition system... PICS INCLUDED
CaptainMak
I went to check to see what kind of ignition system I have to double check the timing on my engine.
Upon digging deep on the Net, I "think" I have the MEFI 3 system. (pics below).
Now, this part is confusing. I thought the MEFI system is only on fuel injected engines, but mine is a 2 bbl carb.
Can someone explain this ?
I found a DIY test light and base time paper clip and LED light here in the forums, but am still confused how I can have the EFI ignition on a carb engine.
Engine serial # 0M019033
Model # 4M31027N1
thumpar
Does it have a throttle body or carb? Got a serial number handy?
CaptainMak
I put the serial number right above the pics. Serial # 0M019033
I think it's the throttle body. 2 injectors with wires coming to them
thumpar
Sorry I somehow missed the text of your post. It is EFI so it doesn't have a carb. I think it is MEFI 3.
achris
More fish than mountain goat
It is a MEFI3, and what you are looking at thinking is a carb is the throttle body injection system.
Fun Times
Sometime the distributor system on these/some EFI engines can be confusing as your engine uses parts from the thunderbolt V designed distributor ignition system used on "some" not all EFI engine models which is also found on carbureted engines too. Other EFI or MPI ignition systems are called Delco EST from Mercruiser.
http://www.boatfix.com/merc/bullet/99/99_02.PDF
Here's your OEM parts catalog for you, http://www.iboats.com/5-0L-EFI-GM-305-V-8-1999-2001-0L331631-THRU-0M299999/dm/view_id.1683216
CaptainMak
Thanks for all the info. Will be checking it out this weekend. Found the diagnostics plug. Now to figure out how to get to the pulley to see timing marks.
