Well, I went to change the oil on my Volvo Penta DuoProp and it seems I have joined the many owners who's forward prop has seized on the outer shaft.
I tried any trick I had to try to get it off, its just not gonna happen. I've accepted I have to cut it off.
That said I will will use this as an opportunity to buy new props.
Is there a per-se 'upgrade' that I should consider or just get the same prop?
I can tell what props are on it now. Where are the marks on the props? And I have a feeling if there are marks there pretty worn off.
Any help is appreciated.
It is a 2001 DP-SM outdrive serial number 4202001529.
