Need help identifying parts in a carb rebuild kit
dolla101
hello everyone ...this is my first time rebuilding a carb (marine) ....i looked at the exploded view and i still cant seem to find these parts they sent in the kit....i need help identifying parts...i ordered the OEM johnson part ...for a 93' 115 model# VJ115TLETS.....the circled parts are the ones im having trouble with ...i've lookied over and over again @ the exploded view and nothing.... any info to confirm the other part numbers(that i numbered)...is appreciated....
mark1961
Ensign
Re: Need help identifying parts in a carb rebuild kit
Like any carb kit, expect to have some additional parts leftover which are not required for your particular application......most of them are made up with the idea of one kit covering all generations of the same carb.
#5 are core plug replacements and will be needed to clean the carb properly.
dolla101
thanks mark...for the info
durban
no 1 looks like the clip spring & the other , the shoulder washer for the choke cam both from round about 1973 to 1976
Faztbullet
The parts you have circled are for carbs with adjustable needles...#1 is the needle valve bearing and #6 is the needle valve retainer. These are for numerous hp and carbs that have adjustable needles
boobie
Agree + 1.
