need help id'ing what these are and use
66mstgfsbk
i have two plugs, i dont know what they are. they are located on the hull on the left and right of the drive. they look like white hockey pucks with a bolt through them. they are made by atwood and have some weird chalky cermaic feel. i dont know why they are there or what they are used for. thanks for any help
smokeonthewater
Re: need help id'ing what these are and use
they look like thru-hull fittings with plugs in them..... look inside the hull for the answer
66mstgfsbk
i pulled those plugs out since i wasnt able to see them in the bilge. it turns out that they were full of water. i also found that i have what looks like a drain in a sink in the rear corners of the deck. when the plugs are pulled the water that drains into the strainers then out those plugged holes. can some one tell me the true purpose of why those would be there. is it for cleaning the deck and the water has a place to drain? or is there some other purpose. thanks for the help.
Frank Acampora
Sounds like bait live well drains.
