95regalskip
- Joined
- Dec 23, 2011
- 13
Hello all,
Don S. Thanks, I hope this is the right place. Great Forum!!
I am new to the forum and this is my first post. I have already found an overload of information.
I have been messing around in boats for years. This is my first outdrive rig.
I have recently purchased a 1995 Regal 256 with a VP Duo Prop.
I think the boat has been re-powered because, I cannot find my boat with a 7.4 option for that year on the volvo sight..
I am trying to figure out which drive I have so I can pull the props and replace the sac. zinc.
I have purchased a Clymer manual for the drives.
When I looked at the boat for the second time, I noticed that the props were bent. The dealer said it had happened when they 'parked' the boat and trailer in the yard, backed into curb and they would have the props repaired for the sea trial. They did. However, they did not replace the sac. zink and I would like to instal a new one.
When I search for a zinc, all I find are zincs for a 280 or 290 drive.
If I read the manual correctly, I think I have a DP-D1 out-drive. Where can I find the serial number/model number? The exhaust is not through the prop hub. There is no adjustable trim fin (?) If that is true, which zinc do I need?
Which prop wrench do I need to remove the forward prop?
Also have a port side leaking trim cyl. that I am going to try and reseal with out completely removing the cyl. from the trans. I think I can pull the ram and reseal and reinstall in-place. What are your thoughts on that endever?
Any help is greatly appreciated.
Thanks in advance,
Skip
Thanks in advance,
Skip
