Demolitron
- Joined
- Sep 17, 2007
- 32
Hello,
Well, I walked away from a Mercruiser 470 powered boat! And then I stumbled into something nicer. I would like to have the community weigh in on this engine and drive.
Mercruise 205 Serial #:454761
Drive Serial #: A396855
Comes in a Four Winns 1985 19' openbow (Horizon 190 I think, can anyone weigh in on this?)
The owner started it for me. It had a VERY low battery and would hardly crank over, but it started up. Is that a good sign, that it started with very low cranking speed? It has been sitting for a year in his side yard. I put a VOM on the battery, and confirmed it was only about 11.5 volts. Otherwise I would suspect a problem with the starter.
I had them put it in fwd and rev, then tried to turn the prop to see if there were clutch dog problems. It would ratchet one way and then locked the other way. Seemed good to me.
Engine oil was slightly tan. The idle was smooth. The circulation water hoses felt warm and the bypass lines felt cold, so I think the cooling system is in order on a rudimentary level.
Thanks for your help.
