need help on midsections
proline20
Hi there i need help. Need to know if i can change mid section on 88 140 hp sea drive 20' shaft using a 90 115 hp 25' shaft and will parts inter change. What i'm trying to do is make the 140 hp a long shaft. Any help will be greatly apreciated. Thanks aigan.:confused
wilde1j
Re: need help on midsections
Check the part nos. on BRP's website.
proline20
Thanks Jim but no go at brp can any one help? can i use mid section from 1990 115 hp 25' shaft on a 1988 140 hp 20' shaft? The motors are both omc sea drives.Thanks for any help:confused:
Dhadley
Sea Drives never really had a hp desigination but we'll assume you have a crossflow (the 1990 115) which should be the 1.6 liter Sea Drive and a V4 looper (the 1988 140) which should be the 2.0 liter Sea Drive.
The V4 looper and V4 crossflow midsections are different assemblies.
proline20
Thanks i do thank you for the help can i take the power heads and swicth them??
Dhadley
The looper and crossflow powerheads are completely different. The crossflow powerhead needs a crossflow midsection (adaptor plate) and vise nersa.
