Need help on old Merc 115... a few dumb questions
lrmccain
First thing, where should water be exiting while running? Right now it's only coming out of the six slots above the prop.... This doesn't seem right to me. I'm pretty mechanically inclined, but this is the first boat I've ever worked on.
The other thing is, the motor wont shift to reverse, I'm assuming this is a cable adjustment issue, (throttles up but doesn't shift) any guidance on adjusting the shift linkage would be much appreciated
Lucas
hammyloz
Re: Need help on old Merc 115... a few dumb questions
water should be exiting from top of the leg bottom of engine block there should be a little hole if no water is coming out shove something down the hole in case its blocked failing that it could be the impellor
lrmccain
Ok, next dumb question, how do I find the model number on this beast, it's an inline 6, 115 hp
Lucas
hammyloz
either on the block itself or down the right hand side of the leg
OldMercsRule
It the motor is 1979 or earlier the serial number will be on a plate rivited on the Motor bracket just under the front of the Power head. The serial numbers on the block should be where the two pieces bolt together. JR
Chris1956
Lucas, Water exiting where you describe is perfectly fine. Actually it is the main water outlet. On the muffs, water may (or may not) come out of the idle relief holes (square holes at the base of the powerhead). It also may come out thru the prop.
If you can find the serial number on the clamp bracket, you can find out the year. If the motor has a distributor, it is pre 1979.
Chris1956
To adjust the shift cable, remove the shift cable barrell nut from its clamp. Push the shift slide ito the neutral position. It will click and stay there, Now set the remote control to neutral. Now adjust the barrell nut to fit the clamp.
Bob_VT
Rule # 1
Get a maintenance manual! Don't try to adjust anything ....... until you read the manual.
Rule #2
If you are unsure or the age/condition of the impeller......... change it and do not hesitate to invest in that small life fluid pump for your outboard.
lrmccain
Thanks for all your guys' help, as far as the model number goes, that's what the guy at the marine shop asked for, but from everything I'm seeing it looks like all I need is the serial number, is this right? My merc is definitely pre-79, I was told 74 (by a failing memory though) is this all the info I need to purchase the correct impeller?
P.S. this is probably the most helpful forum I've ever posted on, thank you all
thibauja
Hi all !! i guess i should have read this post befor starting a new one...
Chris what do you mean by or may not) come out of the idle relief holes
i had no water coming out of these releif holes or pee hole
so i took off the lower unit and connected a hose to coper pipe and i only have water coming back by exaust..bu i heard it going up tru the head
can you help ?
Clams Canino
All the 115's use the same impeller.
-W
