I am considering changing to a stainless steel prop. I have a Lowe FM175 that weighs about 1130 lbs. with a 115 4 stroke mercury on it. The boat has a 80" wide bottom. Currently I am running a 15 pitch Turning Point Hustler Aluminum prop. The diameter of the prop is 13 3/4". Wide open throttle on the mercury 115 is 6400rpm. I am achieving approx. 6300 rpm with a speed of 45 MPH. What SS prop do your recommend for my application and what pitch do you suggest? I would like to keep my top end RPM about the same if possible. thanks for your replies.
