I'm new to here and really glad to be a member with all you fine boaters out there.
I have a problem with my steering hook up... I have a 1976 15 ft sea sprite and i put a 1960 40 hp Johnson Sea horse on it that came off an old boat with the cable steering. My boat has a single cable push-pull type system. The connection on the motor has a bracket thats attached to the motor itself for the cable type. I saw the kits on west marine and can do it, but, when i try to test run it by holding the cable in place, the motor does not seem to turn enough either one way or another. Any ideas on how to hook this up to this boat and would the splashwell system solve my problem? I would go back to the cable steering but mine is a run-about with a walk way in the middle and the cable would be right in the way.
Thank you for reading and hope someone can help.
