CamaroMan
- Joined
- Mar 18, 2016
- 330
Hi all - bought a inflatable last month - had some trouble getting everything setup correctly.. My throttle linkage bolts were mostly corroded - So i took it apart - one had to be drilled out / retapped - anyway -
Im curious how to set the base idle/advance? I have confirmed the pointer location by checking #1 tdc, ive managed to set WOT throttle stop.. Cables are disconnected and all screws backed out -
Dont have a tach so have to go by ear or something.. Seems the primary pickup screw affects the max timing? btw mine calls for 24 degrees cranking - which is almost near impossible to get to - i can maybe manage 26.. I did break the darn plastic advance linkage under flywheel - but could be off more than 2 degrees..
And every time I adjust idle the timing shifts - so caught in a bit of aloop.. can anyone explain what to do here? I do have reference pics of where the screw were more or less - but I want to know how this all works so I can set it up real well..
Heres a vid of it idling before I went and removed the arm.. fyi carbs cleaned, linked and all - motor starts first swing without using fast idle lever -
Does that sound right? I have backed carb screws out 2 turns each - are there vacuum ports on these for a sync?
