thespazticator
- Joined
- Sep 1, 2007
- 2
Hi,
I've recently gotten hold of an old mercury 3.6hp (see picture), probably '78 to '82 model (serial number 8067707) with the intention of fixing it up as a school project. The problem is, when I got it it was missing the gear lever, throttle lever, choke lever and kill switch (basically all the levers) which means I'll have to fabricate new ones. However I don't know what they all look like and where they go (esp. the gear lever) so if any of you have a motor that's the same model any photos of it would be appreciated.
Also, (apparently) water got into the cylinder and seized the motor which means I'll have to pull off the head and have a look. So if anyone has a service manual I'd like to know cylinder head tension specs and stuff.
Any other suggestions would be appreciated. Thanks.
Pic of the cover:
Pic of the cover:
