I am new to the forum and have a question regarding my outboard. I have been following Sherm's water pump replacement directions from BassBoatCentral Tech Tips and everything was going great until it came time to reinstall the lower unit. I followed his advice for rotating the shift coupler clockwise while rotating the propeller counter-clockwise to put the lower unit in forward gear. After getting the splines of both the shifter cable and the drive shaft lined up in their respective places, I put the control box back in neutral but the prop would not spin freely like it should. ( The motor is a '99 Mercury 60hp two stroke.)
I don't know what to do now??? I have taken it apart and tried to reinstall the lower unit over 20 times with no luck.
I notice that while trying to put the lower unit in forward gear by rotating the shift shaft and propeller, I am unable to continue rotating the prop counterclockwise without having it stop abruptly. This may have something to do with the problem, but I am not sure.
I am sorry for the long post, but I am frustrated as all he!! and dont know what else to try.
Thanks for any advice!
