Hey guys!
I've finally started to plan the partial restoration of my father's boat he's passed down to me. Before we begin, I'd like to say that this is my first major boat project.. however, I'm a fast learner and commited to this project. I understand that many would say that it may be smarter to just buy a new boat, but this boat has a lot of sentimental value to me and I would like to put the hard work into it to get it back on the water running properly.
That being said, I'd like to start by making a list of the biggest concerns with the boat I have before asking how to repair them:
1) The floor has a few soft spots, especially around the fuel container (Underneath the center section of floor). However, all the corners and sides of the floor are very sturdy/hard. Engine supports seem hard/sturdy when doing a "knock" test.. and the Transom also shows no signs (as far as I know) of soft spots or rot.
2) The engine is a 4.3L V6 Mercruiser (1986) model with a 4bbl carb. It was rebuilt in 1988 with all new race quality bearing, pistons, rings, rods. However, after firing the engine up with new plugs, fuel line, and fresh oil lubricated into the cylinders. It started up with a very loud metal knocking noise that increases with RPM. After discovering this I shut the engine down and my best guess is that it has a bad rod/bearing in one of the cylinders. My plan for this is to have the engine totally rebuilt or repower it completely (They seem to be about the same price to do either). Supposedly I can get a refurbished low hour engine online for about 3000. My local machine shop says they can do a full rebuild for about 2500. I plan on attempting to pull and crate the engine myself.
3) The trim pump isn't working, tried replacing the solenoids but it still won't work from the control switch.. HOWEVER I think the wiring is rusted out connecting the trim pump to the control, so I think it may still work but the wiring is just faulty. (Still not sure how to "Jump" it to truly test if the motor on it works.
4) The outdrive seems to be in complete working order.. however, the bellows do need replaced and it also needs new sacrifice metal pieces (the little anodes). That is all the repairs that It appears to need (besides maybe an impeller but thats easy)
5) Power steering and electric start are in what appears to be good working order. (Not an issue but worth mentioning for consistency purposes).
6) I HAVE NOT done a "core test" on the stringers to see if they're rotten. I plan on doing that soon.. I understand you do this just by drilling into the stringers with a small bit size and seeing how the shavings come out.
7) Preferrably, I would like to replace the floor and all the foam under the floor but not the stringers.. but this obviously depends heavily on if the stringers are rotten. I know many say "if the floor has soft spots then the stringers are probably bad too" but I have also been told that this is not always the case. I guess my best bet is to pull the deck/floor out and test the stringers myself.
So that is all the issues that I need to focus on repairing for this restore. My goal is to get this boat in proper working order for at least 5-6 years.
Here is how I'm going to tackle the project first along with questions I have about each step:
1. Replace impeller and remove outdrive completely (store in garage until engine is repaired/replaced)
2. Remove engine and crate it. (I am unaware of how to do this but as far as I understand all you need to do is remove linkages to throttle and steering and then remove engine mount bolts, right?)
3. Remove Seats inside boat, (assuming this is a self-explanatory job.. however there does seem to be wood underneath the seats attaching them to the deck).
4. Tear up carpet (Self explanatory)
5. BIG ONE: Begin removing deck/floor of boat. This boat is a cuddy, so my biggest question here is do I need to worry about removing anything up in there? Do the stringers of the boat go up into the cuddy? Also, Removing the deck is mostly cutting it out with a saw-zaw, angle grinder, circular saw.. am I right? I can't find any tutorials or guides that explain from start to finish about how to remove JUST the floor/deck of the boat. I'm also thinking that I should leave a "Lip" of wood at the edges of the floor attached to the boat so I have somewhere to measure/start from when laying down the new deck, right?
Once I get the deck/floor out I plan on digging out all the foam and then once it's all clean I'm going to inspect the stringers and see what I'm working with and if they'll need replaced. I know it's likely that the stringers will have some areas that are beginning to rot.. but I also know that there is a slight chance that they will be fine as well! I'm hoping they're okay and that I can just reinforce them with more wood and fiberglass and putting a brand new deck down. If they do need replaced, I havea carpenter/mechanic friend I plan on tackling that giant project with.
So this is where I'm at so far guys! I want to thank anyone in advance who takes the time to read through my questions and answer each (preferrably in number format) that they are able! Any written tutorials or videos that you guys have on removing the DECK/FLOOR of the boat would be amazing. That is the only job that I am definitely nervous about.
Lastly, I know this is a big undertaking so I don't need to be told so. I'm simply looking for tips and pointers on how to begin this job and any tricks of the trade that will make it easier on me. I grew up in this boat.. so I want to restore it. It will make my dad so happy to see it restored and it will be amazing to start my family with the same boat I had as a kid.
Thank you guys so much for your help!
