First off I have no idea if this motor was actually a great runner as stated by the PO...so far I have seen some pretty incredibly sad wiring so who knows what he did in the past etc. He said it would 'fire right up"...lol
Well after replacing the internal wire harness, cleaning all connections and installing a brand new battery all I get when I turn the key is clickkkkkkkkkkkk...and not a single click but a rapid repeating noise. The noise sounds like a car with a bad battery connection or semi dead battery.
I "think" I have installed all the wires correctly based on the diagram (plus they are color coded) but I could have messed something up somewhere.
Can someone please tell me how to proceed in testing OR bypassing the solenoid...and tell me if the small two wires on the solenoid (yellow and black) matter which post they are hooked too. I did try both ways and got the same result.
When putting a volt meter on the two large solenoid posts without the key turned on I get about 12 volts.
And...if I bypass the solenoid and go directly from battery to starter the starters spins fine....just not by using the key.
Thank you.
Thank you.
