I have a 1989 Evinrude 60 VRO 2 Stroke 3 Cylinder that runs great. It was rebuilt 3 years ago and has less then 10 hours and is still in the break in period. I am running the VRO and oil in the gas tank for the break in period. The warning horn in the throttle shifter is now going off at mid to full throttle. It is an intermitted horn sound that gets faster the faster you go and slower the slower you go. If I go back to neutral and just idle it stops, then I can go mid to full throttle for about 5 minutes and then it does it again. It had a new water pump but not a new thermostat when rebuilt becuase the thermostat was good. I can put my hand on the thermostat housing and it is hot but not hot enough to where I can not keep my hand on it. Any ideas on what could cause this and how to fix the problem? Thanks for the help
