Need help with 1998 PCM 351
barbwire44
The boat is a 1998 air nautique, it has the ford 351 PCM fule injected engine, the intake is cracked in a passage that can't be fixed. PCM does not carry this intake anymore, My question is where can I get one??? and the other question is, is this a standard intake from FORD????
thanx
JUSTINTIME
Re: Need help with 1998 PCM 351
call pcm, i know there is a place in NC that sells pcm parts
rodbolt
ford pulled out of the marine market about 1995, most any ford marinized product since 95 will be a 95 or older model. most the intakes were standard ford products but can be rather rare.
there were a few used by marine power and PCM that are marine specific.
look for the ford oval symbol on your intake. if its there look for a casting number and contact your local ford dealer.
salty87
discount inboard marine can get you just about any part you need for PCM. skidim dot com
