Re: Need help with 2000 evinrude 115 ficht
Sure, if everything else is running fine, it is normal. I have seen DIs (fichts by another name) with a lot of oil in the pan from dripping exactly where you see the seepage. They are dirty, messy engines, just another reason they are no longer made. The oil is built up from the engine not burning it efficiently and the nature of two strokes which pushes it out past the reeds (which are not perfect at sealing).
