need help with 40hp nissan
bone20
hi i gotta 1992 nissan 40hp outboard. i got some problems with (it sat for a couple years before i got my hands on it). first off i had it running great then took it out on the water and it ran good for about 10 min or so and then it lost all power it runs fine when its idoling but when you put a load on it it just bogs down and never revs up and goes i replaced the fuel pump its got good spark idk if i blew it up or what happened to it it seemed to be running a little lean looking at the plugs but not bad enough to pop the motor. if cleaning the carbs out good and checking the compression and everything seems to be ok where should i look next. thanks for your help and if i do have to rebuild it anyone know how much that might cost
pvanv
Re: need help with 40hp nissan
In order to get into specifics, we need your actual model and serial numbers. Year is not important for servicing, but model/serial is critical. First thing you will need is a Factory service manual for specifications and test techniques. If you have the 2-cylinder NS40C, you will want Part #003-21035-1, $44.17; If you have the 3-cylinder 40D or D2, you will want Part #003-21036-1, $44.17, available from any dealer, including me. Since you mentioned carbs (plural), I'm guessing that you have a 3-cylinder D or a D2. That being the case, a manual is very important so that you can do the link-and-sync correctly.
In general, if the plugs came out white, you are probably lean enough to burn a piston. Always check compression to see the mechanical health of the motor. Or... If you accidentally ran without adding oil to the gas (if it's not an auto-mixing model), you may have scraped down the rings, pistons, and cylinders. which might allow the motor to barely run but nothing more. Likewise, if the fuel system is loaded with crud (check all the way from the carb to the tank), or a carb needs cleaning, (or if the fuel filter is plugged) (any of these from sitting for a coupla years), you might idle OK but not deliver enough fuel for more than idle. If you decide to clean the carbs, don't cut corners -- fully disassemble each one -- I mean completely -- and soak each one in real carb dip (such as Tyme) for about 4 hours at room temperature. Then you can blow out the carb passages, reassemble, and reinstall them.
bone20
OK. Verify model and serial, check electrical, fuel and mechanical systems, and see what you have.
where abouts in ny are you if i need some profesional help with this i dont know any reliable places that work on nissans around syracuse that dont charge you an arm an d a leg to work on it
pvanv
Buffalo. But that's still 2 hours from you...
