has 13 3/4 x 15 prop----engine mn--J88MSLCUS--S#---7484182-----WATER SEEMS TO BE PUSHING AWAY FROM MOTOR BAD---MOTORS STILL PUMPING WATER BUT IT SEEMS LIKE IT CAVITATING BAD----WAS TOLD I NEED TO CHANGE PROPS AND PUT A HYDRO FOIL ON IT---ALSO WAS TOLD IT THE ENGINE COULD BE A SHORT SHAFT--I DONT KNOW --IT FITS BELOW THE PONTOONS WELL SO ITS GOING DEEP ENOUGH IN THE WATER FOR SURE---IT HAS TILT AND TRIM SO I CAN ADJUST---ITS AS LOW AS IT CVAN GO ON BACK OF PONTOON--ANY ADVICE ON THE PROP--HYDROFOIL OR ENGINE INFORMATION WOULD BE APPRECIATED---
