Need Help with a 1955 or 1957 Montgomery Ward
Status
Not open for further replies.
garyq
Hi could someone tell me if i need a special puller to take the fly wheel combo ring gear off a 22 hp need to get the carb off but big wheel in my way also its not in running shape but all original pistons are seized took a lot of pic,s taken her apart up to fly wheel .i want to put some rust remover oil in there what do you think !IMG_0330.jpg
nwcove
Re: Need Help with a 1955 or 1957 Montgomery Ward
not completely sure of your motor, but a basic automotive harmonic balancer puller works with a lot of flywheels. 20 buck at canadian tire. (wait for more informed info before you buy one....as i said, not sure about that particular motor!)
garyq
i could be wrong on the model year so here is the model #GG9020A serial # is 55X579351
F_R
You are correct it is a 1955, 22hp, made by Gale Products Division of OMC. It is a Gale model 22DE10. It is very similar to a Johnson and Evinrude 25hp, with smaller pistons so it only makes 2hp. All J/E 25hp service procedures will apply.
Yes, you need a flywheel puller. Most use the harmonic balancer puller. Use Grade-8 bolts with it, screwed in 7/16", no more and no less. Then give it heck and it will pop off. Forget the mechanic in a can stuff. When you go to put it back on, the shaft and flywheel tapers MUST be shiny bright CLEAN and DRY, and you MUST use a torque wrench to tighten the nut to 60-65 foot pounds. Ignore these instructions and you probably will destroy the motor.
Uness they have aready been replaced, it will have bad (cracked) coils, so yes the flywheel does need to come off. Way more important than that carburetor you are trying to get to.
Do it right, and that fine old motor will give many years of service.
garyq
Thanks F_R nice to know I have a 1955 would it be possible to let me know where to get a repair book for that year ! i want to tare the whole engine down and I am no mechanic but i take a lot of pictures to help with the rebuild,,
garyq
I have to tell you guys for a 22 hp motor she is pretty big and heavy when i first saw her i said thats got to be 35 or 50 hp because its as big as my 1976 45 hp but no its a 22 ,this is my first old motor so now i know ,will keep you posted ..
nwcove
gary, if you need odds'n' ends , check out nymarine, hes relatively close, and will have most of the tune up parts you may need.
garyq
nwcove do i look for nymarine here on i boats ? i will look ! will need a lot of help guys thanks so far posted 1 pic and can not post more pic,s something went wrong after I sent first pic oh well ..
1946Zephyr
You can probably find a service manual at the Ken Cook Company or on ebay. It would be a good investment. Like F_R says, you have a dandy of a motor there. In some ways, the old Sea Kings were more advanced than the Johny/Rudes.
garyq
IMG_0004.jpgIMG_0001.jpgIMG_0005.jpgIMG_0003.jpgI also picked up in the summer time I think a 1957 18 hp fast win evinrude that I will be working on,, a real nice find ,to me in better shape than my 22 hp but no time to talk, have to work work work to get it all done :D
wbeaton
Gary, there is an Antique Outboard Motor Club meet in Ajax on Jan 28. If you come to the meet I will give you the Factory Service Manual you need. You can PM me through this site.
Check out the details here...
http://www.mapleleafchapter.org/schedule.html
1946Zephyr
Well, if that is the original shroud on that motor, then it's a '58. Same mechanical difference as a '57. 1956 and '58 models have the name in block letters, where the '57 has the name in cursive. Excellent old motors. You'll love it out on the water. They're very reliable and tough to beat. I've had several of them through the years.
F_R
Sorry, it is a 1955. The only year the 22hp was made. Not only that, the serial number verifies a '55. The number before the "X" is the year in reverse. 55X is a 1955, 65X is a 1956, 95X is a 1959, etc
garyq
Thanks again guys ,best darn boat site anywhere in north america and to the gurus out there many thanks for your hard work coming up with all the answers to are Questions in a very timely manner ,my hat is off to you guys !! I will have many more question for you in the coming months ;)
1946Zephyr
I was referring to the 18 Evinrude. Sorry I didn't clarify that. :redface:
garyq
that was going to be my next question about my evinrude motor ,but now I don,t have to. motor is out in the shed and now i don,t have to find flash light to see serial #,s Thanks 1946zephyr for the info 1958 should be a great motor to bad its to big for my 14 foot SQ Back canoe I just got !! But I will be going to a old boat show on the 28 of this month maybe find a good deal there on a 3 hp....
1946Zephyr
Well, that 18 will push a lot of other nice light duty 14' fiberglass boats and hefty aluminum boats though and you can easily convert it to a single line tank, so you could share tanks with your 22 Sea King. The second boat I owned was a 14' Glasspar and it did fine with an 18 on it. Mine was a year older than the one you have there. That 22hp Sea King will do nice on a 14 - 15' runabout too.
steelespike
While it is physically large it is reasonably light compared to todays electric start 22-25 hp motors.
Your electric start tiller 22 is 125lbs todays Evinrude Etec electric start long shaft tiller with power trim is 183 lbs.
The lightest 25 Etec tiller is 147 and thats lighter than many other brands.
Status
