I have a 86 200hp black max hung off a 85 fineline centurion tunnel. about 5 years ago, the buzzer went bad, and after some stupidity on my part, I blew it up due to lack of oil. I rebuild the entire engine, at the time thinking the only option was to buy a used block. the rebuild set me back about 6250$. <br />last summer, the boat started to run strange. top speed was only about 60 on the GPS (normal is about 77mph). I thought I either had a plug go bad, or a head gasket. I pulled the head and I the top left cylinder (looking from the back) had a hole in the piston on the intake side. The cylinder is trashed also. <br />Is this caused from running lean or from detonation?? Can you re-sleeve just the one cylinder or do I have to rebuild all 6?? it only has about 150hours on the new top end. <br />any other suggestions are greatly appreciated!!!<br />thanks in advance!!!!<br />-Jeff Argo
