need help with a 1989 Blue fin Spectrum 1950 Model with I/O 4 cyl
JUST bought a 1989 Spectrum model 1950 with the 4 cyl I/O motor & issues are popping up !
-when I first bought it, we took it out for a test drive and the battery had to be jump started as it had sat all winter.
We hooked it to a jumper box and had it running on a hose with ears & it fired right up and ran GREAT !
When we put it in the water a 1/2 hour later, Again it fired right up with the jumper box But when we tilted the outdrive down it killed the motor and the jumper box was Too low to jump it again. We jumped it with jumper cables and it fired right up, but we did Not take it out because the battery was too low and the jumper box was dead !
We took it back and they put a small car style battery in it and again we did the same thing ......hooked it to a hose and it fired right up.........put it in the water and it fired right up........we drove it up and dow the river for about 45 mins with no issues and then took it home.
the next Day we took it off the trailer at the dock and no power, I checked the connections and they seemed quite loose , so i moved the terminals around and they must have made contact and it fired right up (with the new Smaller car style battery) and we ran it at the lake for 2-3 hours Straight with no issues.
When we got back to the dock , it would Not re-start to load it onto the trailer .........I again messed with the loose terminals but with no luck this time. When we got back to the house , I tried it again and again it fired right up with no issues. I tried this repeated time and there were NO problems after we got it home !
I tried it several times the Next day before we took it out with the small battery and again no issues, fired right up (with the small battery) .........we had just bought a new Deep cycle Battery so we went ahead and replaced the Small car style battery it had in it ....After we hooked it up, it fired right up and ran like a dream at the house with a hose on it !
I even tried shutting it off and starting it Several times with No issues......we took it to the lake again which is about 45 mins away and launced it and It fired right up. NO ISSUES............ran it for about 15 mins across the lake and shut it off and was going to set anchor, but we decided to move further down the lake and we tried to start it LESS than 2 mins after we shut it off and Nothing , No power..........nothing !
The radio is dead......guages dead..........nothing, BUT the outdrive would trim up & down but NOTHING else has power !!!!
any ideas..........
Re: need help with a 1989 Blue fin Spectrum 1950 Model with I/O 4 cyl
any ideas..........
Ayuh,.... Welcome Aboard,.... Fix the Wiring,... There shouldn't be Loose terminals...
They should be Clean, 'n Tight...
They are tight as can be, and we cleaned them when we put the new battery in. No power to anything EXCEPT the outdrive.
Found the issue.......not a loose cable, it ended up being one of the 50 Amp (tube type) fuses had literally come apart inside the rubber boot . The metal end caps had come loose and seperated from the housing and was allowing the metal inside the fuse to shake freely inside the round fuse housing which would allow intermittent connection and would make it a loose connection which ended up with us losing total power to everything Except the outdrive !
What I thought was a Massive issue, ended up costing me $1.59 at my local NAPA store !
FYI , these fuses are hard to find, and rarely used so you might pick some up if you find them, there are 4 of these fuses on my 2.3l motor so I replaced the all and got some spares and threw in my tool box just in case !
