I have the transom mostly stripped down couple of questions though
1 cracks found under wood the transom was rotted gone except the upper 2inches
2 when they layed the wood in the transom left voids at the bottom do I need to grind flat or add thicked epoxy and fill when I lay up the new wood?
3 any suggestions for the process of glassing this type of transom in due to it not flat also what mat is recommended?
Thanks im sure Ill have more questions due to this has turned into a major ohaul
