Need help with a transom drain!
john51277
I have searched this site, googled, yahooed, I even asked jeeves! I am looking for a nylon/plastic transom drain. The kind that has a tube that goes through the transom and is threaded with a flange on both sides, and also has the threaded plug with the rubber o-ring on it. I have one on my Key Largo and love it!
mthieme
Re: Need help with a transom drain!
There has to be more to the story.
These are available everywhere.
john51277
clarkw,
That looks like it snaps together, I want one that screws together. I also want one that has a screw in drain plug. I just cannot find one. I have found thousands of other kinds!
jonesg
I have something like that, but its the thru hull fitting for the bilge pump, it mounts above waterline on the side of the boat where the water is dumped out.
Its white and threaded, its also sealed with 5200.
Maybe take a look at those fittings.
