I need to add a bilge pump to my boat but I have a problem with the location. I have an 18.5 center consol that the deck sits low in. I found that the bilge needs to pump the water out above the water line. My deck sits below the water line or right at it. Is there a bilge pump that has enough power to pump water out under the water line and will not let water in. another idea was to run the bilge through the floor up to the transom and over it. The only problem is there thats a lot of line to pump the water. Can any one here help me out with this?
